Classic Shell V.2.9.2
13 мнения в тази тема
Въпреки, че вероятно най-добрия начин да върнете класическото старт меню е този: Натисни тук , ето още едно предложение, което обаче ви дава възможност да модифицирате и Windows Explorer
https://windows7bulgaria.com/imageupload/images/5664ClassicStartMenuandExplorerfeaturesforWindows7.jpg
Съдържа две части:
Classic Start Menu:
Оригиналното старт меню, познато от XP. Някои от характеристиките включват:
* Drag and drop to let you organize your applications
* Options to show Favorites, expand Control Panel, etc
* Shows recently used documents. The number of documents to display is customizable
* Does not disable the original start menu in Windows. You can access it by Shift+Click on the start button
* Right-click on an item in the menu to delete, rename, sort, or perform other tasks
* Available for 32 and 64-bit operating systems
Classic Explorer
Плъгин за Windows Explorer, който:
* Adds a toolbar to Explorer for some common operations (Go to the parent folder, Cut, Copy, Paste, Delete, Properties)
* Replaces the copy UI in Vista and Windows 7 with the more user-friendly “classic” version similar to Windows XP
* Handles Alt+Enter in the folder panel of Windows Explorer and shows the properties of the selected folder
* Has options for customizing the folder panel to look more like the Windows XP version or to not fade the expand buttons
ClassicShellSetup_2_8_3.rar
8
Нова версия - v.0.9.8 - с поддръжка на скинове.
Архивът в първия пост е обновен!
https://windows7bulgaria.com/imageupload/images/628skins.png
Щракнете за оригинален размер
Промените в новата версия:
# Added support for skins in the classic start menu
# Fixed compatibility problems with Unicode-unaware shell extensions (Microangelo On Display, I'm looking at you)
# The start menu supports auto-hide taskbar and (on Vista only) a taskbar that is not "always on top"
# Replaced the folder conflict dialog box with a simpler version (similar to the file conflict dialog box)
# Fixed a crash when right-clicking on the caption area of the start menu
# The start menu remembers the scroll position of scrollable menus
# Added "-open" and "-toggle" command line parameters to ClassicStartMenu.exe to programmatically open the start menu
Официален сайт: click-me.gif
Уроци за скиновете: click-me.gif
Добра работа. :yahoo: Може ли след това да се деинсталира и то успешно? Ако някой е пробвал да каже
А мога ли да направя промените само върху Explorer без да променям старт меното на Седмицата?
Може :) При инсталацията си избираш какво да бъде. Аз така направих - само explorer ;)
Добре че е БЪЛГАРИН да направи такава програма :)
Нова версия на програмата с доста подобрения и изчистени бъгове. Първият пост в темата е обновен!
https://windows7bulgaria.com/imageupload/images/8914toolbar.png
Списък на промените (от версия 0.9.8 насам) можете да видите тук: click-me.gif
Подробности в официалния сайт: click-me.gif
Ъпдейт на програмката :) Първият пост е обновен с новата версия - 2.8.3
Авторът често обновява и разширява функциите на програмата, затова най-добре да прочетете за новостите и промените в официалния сайт: Натисни тук
А тук е доста подробна галерия с функциите: Натисни тук
Темата отдавна не е обновявана, но има нова версия от декември 2010, която добавя доста нови функции и графичен интерфейс на всички настройки и опции.
Промените тук: Натисни тук
ClassicShellSetup_2_9_2.rar
ClassicShellSetup_3_0_0.rar
Новата версия.
На мене си ми харесва оригинала, но всеки с мнението си :)
Само не разбрах как се връща тул бара в експлорър. Нещо неще да стане при мен.
Classic Shell Version 3.6.5 Натисни тук
Classic Shell v3.6.8
промени по версията от 3.6.6*
- Added support for Windows 8.1 Preview
- Modified the Classic Shell logo and removed the Metro button by request from Microsoft
- Fixed some bugs found in the previous version
- Fixed incompatibility with the taskbar of Windows 8 and Windows Server 2012
- New setting to disable the taskbar transparency
Свали (8.4 MB)
